The Sensing of your sensors sensitivity....?
While traveling around offering my services to wonderful cirrus owners I have once again a good story to tell and hopefully we can all benefit.  This one starts with a prop balance.  I traveled to the clients home base and performed the routine service.   We calculated the balance down to the 'gazinth' of a gram and I proceded on my way home.   Several days later I received a phone call,  the client reported about his last flight.  I wouldn't say this was an eventful flight but it wasn't "eventless".  On climb out the MFD was indicating  high EGT and CHT temperatures on the #6 cylinder, he landed and had maintenance examine the problem.  ( Discovering a cracked fine wire spark plug).  I asked him to also send me the Emax download.(see below figure 1).   Here is what the pilot of the SR-20 had to say and I quote " I would have pulled back power much sooner, however due to the history of erratic indications I second guessed the situation and delayed my first instinct."
The flight in question...with calculated peak temps for the #6 cylinder...note the #5 is also climbing....
Calculated probable peak CHT values
Remember my New Years Eve flight in Duluth?  The pilot did not believe his instrumentation...(and with good cause)...sensor connectors have been shown unreliable.... to the point of pilots discrediting REAL PROBLEMS.
When you don't trust the data presented, make the system reliable....act on the results as "true" until proven "false"
Next ....what is happening to the cylinder after the high temp event?
Posted 9 Jul 2009 9:23 by Jim Barker
Michael Bonnell wrote re: The Sensing of your sensors sensitivity....?
on 16 Feb 2010 13:47
I regularly get a cht spike ONLY on #5 and usually right after starting the engine. All other cht's indicate normal temp. I watch #5 climb and often spike into the red. It settles down in a minute or two. I really don't believe the reading because the temp is off to the races and moves up so quickly after engine start. I've had the spike in flight twice and it settled down in under a minute. Injector have been checked. Any idea's for me? Please email me at mbonnell1962@yahoo.com with recommendations.
Thomas Koll wrote re: The Sensing of your sensors sensitivity....?
on 10 Oct 2010 8:27
yesterday, approximately 3 minutes after departing, and still climbing out, i had what I percieved to be approx 1/3 second of a rough engine, as if one of the cylinders didnt fire properly. (it went away as soon as it occured) It has never happened before, and I have about 700 hours on the plane. I downloaded the engine data, and used the engine log analyzer web site to look at rpms, temps, etc, and compared the data over the past year....I noticed that the charts show a rather consistant 10 rpm variation while in cruise. It looks as if my engine has always shown that characteristic, and I wonder if that is normal.  I have some other characteristics that may be related: my oat temp on mfd shows 61 F and the pfd shows 10 C, thats a 50 F difference. My psuedo analog tachometer twitches occasionally about 100 rpm back and forth, and the left gas tank needle sometimes stays in the "full" position. To me, it seems possible that a controller, or a sensor might be bad.....not sure if these can even be related.
