Let's be straight. Flying is risky, and nothing can eliminate all of the risk.
The CAPS parachute system offers a Cirrus pilot one last safety option. But it may not be the best option.
The thread, G3 Turbo Down on Highway in Duluth Today, prompted several concerns. This incident involved a demonstration flight that developed engine problems and ultimately an engine failure during the return to airport. The pilot landed safely on a rural highway with wide shoulders and reportedly no traffic, parallel to the north shore of Lake Superior.
With this successful off-airport landing, a chorus of posts arose to question the use of CAPS and the "pull early, pull often" mantra.
No doubt, a CAPS pull over Lake Superior would be highly risky. The water is very cold. Even in summer! Rescue will take time. Water landings under canopy have seriously injured the occupants. CAPS would not be a good option.
With prevailing winds blowing off the north shore, gliding back to land will face headwinds, hence you would cover less distance. A CAPS pull reduces your forward velocity to zero relative to the wind. Activating CAPS before gliding far enough on shore could result in being blown off shore by the wind. CAPS would not be a good option.
The highway in this incident was wide, relatively straight, without traffic, and rural with few structures or power lines visible in the news photos. The pilot from Cirrus Design was local and likely flew this route many times during demonstration flights. Local knowledge of good off-airport landing sights is a big advantage. Between a rolling off-airport landing on a wide, unobstructed road and a CAPS descent, CAPS would not be a better option.
Where else might CAPS not be the best option?
Fires?
Descending under canopy at 1700 feet per minute may keep you longer in proximity to the fire and smoke. If you have control, an emergency descent can be accomplished in excess of 5,000 feet per minute, three times faster. CAPS may not be the better option.
Inhospitable terrain?
If you have control, then maneuver to more hospitable terrain. Can you avoid cliffs or canyons and glide to a treed valley or slope? Can you maneuver to a mountain lake? Immediate activation of CAPS may not be a good option.
Near ships on the water?
One piece of advice when ditching of activating CAPS over water is to position your airplane in front of the boat or ship. You may be more easily seen by those looking forward of the ship. Bigger ships can take a long time to turn around. Immediate activation of CAPS may not be a good option.
High speed descents?
The demonstrated deployment speed, Vpd, is 133 knots. The canopy rigging tests were at 187 knots. One fatal accident involved the parachute separating from the airframe when the descent exceeded 270 knots. CAPS may not be a good option.
Except when you have no other better options!
Ultimately, CAPS is a safety feature that must be activated to do its work. Activation requires a decision to act. And a decision requires making choices.
As a Cirrus pilot who flies an aircraft equipped with CAPS, please plan ahead, think through the choices, prepare yourself, then practice.
Cheers
Rick
2 Jan 2009 14:22
Rick Beach
